Wavetek 395 Arbitrary Waveform Generator Teardown
I picked up a Wavetek 395 arbitrary waveform generator on eBay a few weeks ago. Wavetek 395 is a single channel, 12-bit resolution DDS AWG with a maximum clock frequency of 100 MHz. While the operation manual is readily available, I could not find the service manual anywhere. So I was curious to see the construction inside. In this post, I will show you some of the teardown pictures. If you want to see a video of the teardown along with some analysis, you scroll towards the end of this post.
w395_awg
From the datecodes on various components we can tell that This AWG was made sometime between the late 1990’s and early 2000’s. Although it is more than 15 years old, it’s specifications compare quite well with a modern AWG like the Rigol DG2041A or a Keysight 33250A. Although most modern AWGs support more advanced modulation schemes (such as BPSK, QPSK, OSK, etc.). But for hobby use, Wavetek 395 is more than adequate.
Here are a couple of pictures showing the top and the bottom of the PCB upon opening the case and removing the switching power supply. A single 4-layer PCB is used in this AWG. Since all components used are through-hole, everything is populated on the top layer only. The inner layers are for the power and ground planes. For high speed circuit, this kind of ground and power plane arrangement can reduce unwanted noise significantly.
w395_top w395_bottom
The power supply used is an off-the-shelf switching power supply with a 5V and -5.2V rails and ±17.5V rails. The power supply is rated at 207W, which is more than adequate for the AWG. During my limited testing, the actual power consumption never exceeded 50W. Like many older switching power supplies, this one does not have any power factor correction (PFC) circuitry and thus the power factor is quite poor at around 0.6.
w395_ps1
The main clock crystal used in Wavetek 395 is a FOX F1144H series 10 MHz oscillator. With a frequency stability of 100 ppm, it is not a superb frequency reference by any means. But you can always use an external more accurate clock source if more stability is needed. From the pictures below, you can see a MC1648 VCO, which is most certain used in a PLL circuit to synthesize the variable clock frequencies required for the arbitrary waveform generation.
w395_mainclock w395_mainclock1
In the picture to the left below, you can see 6 TC551001 chips. These are 128kx8 SRAM chips. Together they provide the 256k points waveform memory needed for the waveform generation. This unit is equipped with option 1 (256k-point waveform memory), and the standard configuration has only 64k points waveform memory. The content of the waveform memory is backed up with a Lithium battery.
You can also see a few EPROMs in the picture, these are presumably for firmware and calibration data storage. In the picture to the right below, you can see a Wavetek branded chip. I could not find any information on it, but it is most likely a custom ASIC for some AWG logic.
w395_mem w395_ags4804
In the close-up picture below, you can see a LT1004 2.5V voltage reference sitting underneath the mains power switch. And there are two general purpose 12bit DACs (MB88351) in the vicinity. Given their relatively limited performance (2.5MHz) and their proximity to the voltage reference, my guess is that they are probably used to generate some required reference voltages.
w395_bat
Below are a couple of pictures showing the output portion of the circuit. High speed transistor pairs 2N5943 (NPN) and 2N5583 (PNP) are used to form the push-pull output stage. You can also see many relays for switching various signals. The chip tucked in the upper left corner in the image to the left is an AD9712 12-bit 100 MSPS DAC, an ECL compatible fast digital-to-analog converter. This is the main converter that drives the output stage. Because it uses ECL logic, there is a 100329PC ECL/TTL bidirectional translator chip below it.
w395_dacoutput w395_output
In these pictures, you can see two custom filter packages mounted on ceramic bases.
w395_relay w395_filter
Here you can see an AD834 a 500MHz four quadrant multiplier. And CLC409 is a wide-band low distortion operational amplifier.
w395_relay1
Power from the main switching power supply unit is further regulated via the on-board linear regulators. A few MC10H125 quad MECL to TTL translator chips can also be seen here.
w395_ps
The microcontroller used in the Wavetek 395 is an MC68331CFC16 32bit M68000 compatible microcontroller. You can still buy these MCUs on DigiKey today and they are quite expensive, costing more than $30 each. The unit I got also comes with the GPIB option, so you can also see the scoketed NI IEEE-488 controller chip below.
w395_gpib
15 Comments
  1. […] extensive teardown by Kerry D. Wong, this time of an early 1990s-era waveform generator by Wavetek. Because if the product manual doesn’t contain any images whatsoever of the unit, the only […]
  2. Uriah Dailey says:
    Hi Kerry
    I was wondering if you have any arbitrary waveforms for this gen in a file you could share with me. My gen came with none.
    Uriah
  3. Mono says:
    Hi Kerry,
    thanks for your great review! I recently got a faulty unit: Resistor R163 near the output has been fully toasted and the waveform output is distorted (frequency is okay). Could you please make a quick look into your generator and identify what value this resistor is? I hope you can read the description/label on the resistor because measuring in circuit will not work; too many other components in parallel..
    thanks in advance
    Mono
    • kwong says:
      Unfortunately, I can’t read it without having to desolder it first. But the resistance across R160, R159 and R163 all measured to be 83.6 Ohm, if that helps.
      • Mono says:
        Thanks for looking! I got already a reply on EEVBlog forum. R163 is a 150 Ohm 0.1% precision resistor. I can confirm the 83.6 Ohm too. the I soldered in a 1% as a temporary substitute but still got the distorted output. I suscpect that some active components are faulty too. Will be a challenge for many weekends without schematics at hand…
  4. Sam Reaves says:
    Kerry,
    A couple of things:
    Option 1 is GPIB and DSO upload/download
    Option 2 is the extended memory.
    Since yours has the extended memory would you please look around in there and see if there are any configuration jumpers or zero ohm resistors that are used to configure that memory?
    Also I have a print quality manual for that generator that a fellow from Fluke sent me years ago. I can email it to you. Please contact me by email and I will send it on out. You can post it on your
    site if you wish.
    Thanks,
    Sam Reaves
    • kwong says:
      Thanks for the info Sam! I looked around the board and didn’t see any jumpers nor zero Ohm resistors. Since all 6 memory chips share the same address line, I suspect that it only needed a firmware tweak if all memory chips are available. If you could send me the PDF document, that would be great! Thanks in advance and I will post it here.
  5. Bernardo says:
    Hey Kerry,
    Thank you for the great teardown. Images and descriptions are helpful.
    I’ve been looking at a 395 I picked up from EBAY. Power-up complains about battery being dead. Not so. Battery voltage is at cmos ram when power off. Also lots of distortion at upper frequencies. Someones been it it before. No apparent damage but can’t tell if the 4 high speed cmos rams have been replaced or resoldered. Looks like I’ll be troubleshooting this one for awhile. I have a revision B main board dated 5/94. I would be interested in exchanging, verifying, discovering information regarding this fine piece of engineering.
    Thanks,
    Bernardo
    • kwong says:
      Just curious, is the waveform distortion the same for different waveform types at higher frequencies? What kind of distortion is it? It could be the output amplifier.
      • Bernardo says:
        Square wave only. Unit passes procedure G.3.2 (6mhz @ 8vp-p). Rise/fall times are averaging 5.8ns which is well below spec. Rise/fall slope is linear until about 65% where slew rate begins to drop. It appears I have missing harmonics or ringing caused by scope probe connections. As I increase the frequency towards 50mhz at around 35mhz the top 15% becomes nonlinear on the down swing. At 37mhz the square wave looks like a sine wave with rise/fall times of about 6.5ns. In summary I need to evaluate my probe connections and acquire a 50ohm BNC cable. All scope tests were performed with TDS540C.
        • kwong says:
          I just tested the rise time on mine and the result is very similar to yours. I got a 6ns rise time (6MHz 8Vpp) using coax with 50 Ohm termination on my Textronix 2465. And the waveform also looks like sine wave above 35MHz.
  6. Bernardo says:
    Thank you the waveform verification. After considering the signal path and the settling time specs for the DAC(AD9712 30ns) and it subsequent current to voltage op amp(AD9617 14ns) I find the waveforms are within the data sheet specs for the respective parts. At 50mhz the rise and fall times are nearly 50% of the period. Adding settling time to the signal will of course give what we see, a sine wave beginning at approximately 30mhz. I now believe there are no signal problems with any waveform. Now on to troubleshoot “Startup message – Battery-backed RAM contents invalid. Check battery.”
  7. Edward Ordookhanian says:
    Hello Kerry, I watched your videos on 395 on you tube, I do have a defective 395 but can not locate schematic or service manual anywhere. I was wondering if you have a copy ? And if you would be kind enough to forward it to me.
    Appreciate it in advance
