Canny Edge Detection Auto Thresholding
In the example I gave in “Interfacing IPP with Magick++“, I illustrated how to use Intel’s Integrated Performance Primitives (IPP) to perform edge detection. One issue with Canny edge detection algorithm is that we need to specify a high threshold and a low threshold. How to select those threshold values affect the quality of the detected edge greatly. And in my previous example, the threshold values were chosen manually. In this blog post, I will examine a couple of simple methods that can be used to automatically determine the threshold values.
The simplest way is to use the mean value of the gray scale image pixel values. As a rule of thumb, we set the low threshold to 0.66*[mean value] and set the high threshold to 1.33*[mean value]. Another way is to use the median color in the gray scale image and uses 0.66*[median value] and 1.33*[median value] accordingly. For typical images, these two methods achieve comparable results.
For example, the following shows the picture of a building along with its histogram (original image from Microsoft Research Digital Image. Please see Microsoft Research Digital Image License Agreement for more information):
Building
Building
Building Histogram
Building Histogram
The following shows the edge detection results using Canny algorithm (left image uses mean value auto-thresholding, right image uses median value auto-thresholding) and the results exhibit very little visible differences.
Building (Canny Mean)
Building (Canny Median)
However, for images has non-equalized histogram (see the picture of cloud and its histogram below):
Cloud
Cloud
Cloud Histogram
Cloud Histogram
Canny Edge detection result based on mean value auto-thresholding is pretty poor (see image on the left below), while edge detection based on median value auto-thresholding achieved much better result (see image on the right below)
Cloud (Canny Mean)
Cloud (Canny Mean)
Cloud (Canny Median)
Alternatively, we could have performed histogram equalization on the image first before applying Canny edge detection with mean auto-thresholding:
Cloud Equalized
Cloud Equalized
Cloud Equalized Histogram
And after image equalization, both mean and median value auto-thresholding achieved similar results.
Cloud Equalized (Canny Mean)
Cloud Equalized (Canny Median)
So the Canny edge detection using median value auto-thresholding seems to adapt to different types of images very well (note selecting the median value selection can be thought as equalizing the histogram, except that the pixel values are not changed during such operation).
The following is the code listing for the histogram calculation using IPP (based on the image class I created earlier)
/** @brief Get the min max mean value statistics for the current image
 *   @param min, max, mean: these are output parameters that are passed
 *         back by reference.
void IPPGrayImage::MinMaxMean(float& min, float& max, double& mean)
    IppStatus sts;
    IppiSize origImgSize = {_width, _height};
    sts = ippiMinMax_32f_C1R(_imgBuffer, _width * PIXEL_SIZE, origImgSize, &min, &max);
    assert(sts == ippStsNoErr);
    sts = ippiMean_32f_C1R(_imgBuffer, _width * PIXEL_SIZE, origImgSize, &mean, ippAlgHintFast);
/** @brief Calculate the histogram of the image
 *   @param nLevel: the number of bins in the histogram
 *        levels: this is the optional levels user can pass in (histogram will be then
 *                calculated with these levels instead of the uniform levels by default.
 *   @return an integer array which contains the histogram.
 *   @note the histogram is by default calculated using uniform bins across the color range.
unsigned int * IPPGrayImage::GetHistogram(unsigned int nLevel, float levels[])
    IppStatus sts;
    Ipp32f* l = new Ipp32f[nLevel];
    unsigned int* bins = new unsigned int[nLevel - 1];
    float minVal = 0, maxVal = 0, stepVal = 0;
    double meanVal = 0;
    if (levels != NULL)
        for (unsigned int i = 0; i < nLevel; i++)
            l[i] = levels[i];
    else
        MinMaxMean(minVal, maxVal, meanVal);
        stepVal = (maxVal - minVal) / (float) nLevel;
            l[i] = minVal + stepVal * i;
    sts = ippiHistogramRange_32f_C1R(_imgBuffer, _width * PIXEL_SIZE, origImgSize, (Ipp32s*) bins, (Ipp32f*) l, nLevel);
    return bins;
6 Comments
  1. rob says:
    is there any vb6 code for canny autothresholding? tnx!
  2. mehdi says:
    i need canny edge detection in vb(source code )
    please help me
    tnx
    • lily says:
      #include”stdafx.h”
      #include “cv.h”
      #include “cxcore.h”
      #include”cvaux.h”
      #include “highgui.h”
      int main()
      IplImage* newImg = NULL;
      IplImage* grayImg = NULL;
      IplImage* contourImg = NULL;
      IplImage* cannyImg;
      //parameters for the contour detection
      CvMemStorage * storage = cvCreateMemStorage(0);
      CvSeq * contour = 0;
      int mode = CV_RETR_EXTERNAL;
      mode = CV_RETR_CCOMP; //detect both outside and inside contour
      cvNamedWindow(“src”, 1);
      cvNamedWindow(“contour”,1);
      //load original image
      newImg = cvLoadImage(“C:/Documents and Settings/welcome/Desktop/tom2.jpg”,1);
      //create a single channel 1 byte image (i.e. gray-level image)
      grayImg = cvCreateImage( cvSize(newImg->width, newImg->height), IPL_DEPTH_8U, 1 );
      //convert original color image (3 channel rgb color image) to gray-level image
      cvCvtColor( newImg, grayImg, CV_BGR2GRAY );
      cvShowImage( “src”, newImg );
      cannyImg = cvCreateImage(cvGetSize(newImg), IPL_DEPTH_8U, 1);
      // canny edge detection
      cvCanny(grayImg, cannyImg, 50, 150, 3);
      cvNamedWindow(“canny”,1);
      cvShowImage( “canny”, cannyImg );
      cvReleaseImage( &newImg ); cvReleaseImage( &grayImg ); cvReleaseImage( &contourImg );
      cvReleaseMemStorage(&storage);
      return 0;
    • lily says:
      this code should be pasted in visual studio and also run opencv on ur sys to run the code. contact me on my e-mail if u hve any doubts, i did as my proj this sem so i can help u..
  3. Gustav says:
    Your code will miss the values in the last bin i.e (maxVal-stepVal)->maxVal. your array only assigns bins between minVal and minVal+stepVal*(nLevel-1).
    If you had 20 bins, a min of 20 a max of 220 you would have a step of 10 which would give you a max bin value of (20+10*(19))=210 so your histogram would never have any values for the bin between 210 and 220. The ippiHistogramRange_32f_C1R function requires the max value to be the last pLevels array.
    try
    unsigned int* bins = new unsigned int[nLevel];
    for (unsigned int i = 0; i <= nLevel; i++)
  4. Gustav says:
    fogot to add
    Ipp32f* l = new Ipp32f[nLevel+1];
