Working With LM19 Temperature Sensor
LM19 is an analog temperature sensor that operates over a while temperature range (-55 to 130 Celsius). It is very easy to interface it with a microcontroller due to is fairly linear voltage output.
The following code listing illustrates how to obtain temperature readings from LM19 with an Arduino. The code assumed that the sensor output is connected to Analog 0 pin.
void setup()
    Serial.begin(9600);
  float vin = 5.0 * analogRead(0) / 1024.0;
  Serial.print(vin);
  Serial.print("  ");
  float tempC = (1.8663 - vin) / 0.01169;
  float tempF = 1.8 * tempC + 32.0;
  Serial.print(tempC);
  Serial.print("  ");
  Serial.println(tempF);
  delay(100);
In the code above, I used the approximated linear transfer function shown below. It is fairly accurate when the temperature range is around room temperature.
\[T_{Celcius} = \frac{1.8663-V_o}{0.01169}\]
For more accurate temperature measurement over the full operating range, the following equation can be used:
\[T_{Celcius} = \sqrt{2.1962 \times 10^6 + \frac {1.8639 - V_o}{3.88 \times 10^{-6}}} - 1481.96\]
2 Comments
  1. Arduino Fan says:
    why have you multiplied analog(0) by 5 then divided by 1024?
