IE7 Meta Refresh Issue Update
April 4th, 2007 by kwong
In a post last year I mentioned that there seemed to be an issue with IE 7 processing <META http-equiv="REFRESH"> html tag. And there seemed to have been many people with similar problems.
Recently however, I found out that IE 7 does have the ability to process this tag (see screen shot below). The setting to allow META REFRESH is turned off by default in IE7 for some reason, which resulted in many website compatibility issues.
I am not sure if this option was there all along or not, but clearly it was not easy to spot it at the first place. Anyway, I am still not quite sure why this feature is turned off by default. It doesn’t seem that this setting significantly enhances the security of the browser but it does seem that it has caused quite some annoyance for the end users.
Posted in Miscellaneous |
2 Responses
  1. Beverley Says:
    Gee, thanks Microsoft. Would have been nice if there was a “prompt” option along the lines of “This website is trying to redirect you to xxx. Do you want to allow this?”
    Thanks very much for finding & explaining this, I was going crazy wondering why my website “stopped” working!
  2. Thomas Says:
    Thanks for finding this. It has indeed caused quite some annoyance for the end users as it breaks a lot of sites. A prompt would have been nicer than implicitly denying the redirect, but given the backlash to Vista’s constant prompting, I’m sure Microsoft was avoiding trying to make more. Oh well, another version leads to another work around.
Leave a Comment
Please note: Comment moderation is enabled and may delay your comment. There is no need to resubmit your comment.
