I just picked up another high voltage power supply, this time it is a working Bertan/Spellman 225-20R 20kV one. Unlike the Bertan 205A-05R that I did a teardown with last time which was entirely analog, this one can be controlled digitally either via the front panel or via GPIB from the back. In this blog post, let me share some of the teardown pictures with you. If you are interesting in seeing some cool experiments with this high voltage power supply, you can scroll down and watch my video towards the end.
front
The form factor of the 225 series is identical to that of the 205A-05R. Instead of using one pair of 2N6578 for the DC-DC converter stage in 205A-05R, two pairs are used in the 225-20R. Although the maximum output power of these two units are quite similar (20kV/1mA vs 5kV/5mA).
back
Because the maximum output voltage of the 20R model is 20kV, an MHV (high voltage BNC) connector is no long sufficient. The picture below shows the high voltage connector used in this 20kV power supply. I am not quite sure what this connector is called. It is roughly 1 inch in diameter and has two concentric rubber shrouds to prevent arcing. If you have more information on this connector type, please leave me a comment.
hvconnector
This power supply did not come with a mating connector, since I could not figure out what kind of connector it was I had to make my own. Luckily, it is not too difficult to come up with a DIY version. Here is the one I made with a plastic bottle cap, a section of a plastic tube and some high voltage wires. It serves the purpose well.
hvmatingconnector hvmatingconnector1
The pictures below are the top and bottom views after the panels are removed. The large potted section towards the right houses the high voltage DC/DC converter and transformer. The acrylic block in the upper center section can be manually reversed. It controls the output polarity (switch between center positive or center negative).
top bottom
Here are a couple of pictures of the main analog board and the power supply section. Besides some OpAmps and regulators, there is not too much going on here.
main transformer
Here is a picture of the voltage reference chip located on the main board. It is a AD586K 5V precision reference, with a 15 ppm/°C temperature coefficient. Most ICs in this unit were manufactured during or before 1999, which suggest that this power supply was also made back then.
voltageref
All the digital circuitry is located on the board mounted on the back of the front panel. There are actually two boards stacked together, one houses the circuitry for the display and keyboard input, the other one is the brain of the power supply which is shown here.
controlboard
The metal can in the picture below is another precision voltage reference IC, AD584L. The “L” version has a very impressive temperature coefficient of 5ppm/°C. These precision, low tempco and low drift voltage references are essential for the stability of the HV output.
ad584
Also located on the digital board is a 14-16 bit ADC ICL8068. Given the 0.1uA current resolution and 1V voltage resolution, at least 15 bit of resolution is needed for the read back.
adc
Another 14-16 bit ADC ICL7104 is also located on the digital board. Depending on the design of the power supply, one ADC could be used for current sensing and the other could be used for voltage readback.
icl7104
The DAC onboard is an AD7546 16 bit DAC. Again, to guarantee a 1V voltage resolution the output DAC needs to have at least 15 bit of resolution.
ad7546
The main processor used is an Intel P8085AH microprocessor. Note the datecode on the chip, while almost all other ICs were made in 1999 but this 8085 was actually made in 1976!
gpib8085
In the video below, I did a walk through of the internals of this power supply and also included a few interesting experiments:
12 Thoughts on “Bertan/Spellman 225-20R HV Power Supply Teardown”
  • That’s a nicely built unit, hard to believe it’s from the same manufacturer as the last one!
    BTW, the 1976 date on the 8085 is the copyright date, not the manufacturing date.
  • Hey, I am also looking for the type of connector for my BERTAN 225 series powersupply. Have you found what the connector is and where to find it ? Many thanks.
  • Hi Dr.,
    I just purchased a 225 10KV. It did not come with the HV out cable like yours. Can you make us one like the one you did? Of course we will pay for it?
    If you send me your email I will send you a picture of the unit.
    I look forward to hearing from you.
    Best wishes,
    Nelson
  • That connector looks like a mil-spec round connector.
    There are different manufacturers, but there are nice tables of contact arrangements in the Amphenol 97 series catalog.
    Googling for images, Amphenol 97-3106A-18-420P looks like a promising mating part (but expensive).
    You might want to cross-check measurements with the drawing.
  • Hello Kerry,
    “Note the datecode on the chip, while almost all other ICs were made in 1999 but this 8085 was actually made in 1976!”
    No, as already said, this is the date of the copyright. The production date (PD) is not printed, maybe it is on the bottom of the chip. The copyright is always older than the PD … ;)
    Regards,
    Eric
  • Hi Kerry,
    I’m impressed with the knowledge you are presenting in your videos.
    In the Berten 225-20R I own, when I turn on the HV switch and adjusting the voltage level, sparks start erupting from the HV plug.
    My understanding is that it shouldn’t happen.
    I will highly appreciate if you will be able to comment on that.
    I’ve taken a video of it and will be happy to share it with you.
    Many thanks for considering my request.
    Zvika
